Sponsored by: CARiD
battery problem?
Old Dec 13, 2006 | 10:07 AM
chevygirl's Avatar
Default battery problem?
I just replaced my battery because the last one was leaking acid on the positive side. I cleaned everything up really good and now the green powder is back coming from under the boot on the positive side post cable. I can't figure out what is going on. There is green powder on the inside fender under the positive side. I do not see anything wet on the battery though on that side. The bolt is clean and has no powder on it. When I drive the car at night and when it shifts with a load on it the headlight will dim for a second. Any ideas????
Old Dec 13, 2006 | 07:16 PM
BlackScreaminMachine's Avatar
Internet Mechanic
You need to neutralize the acid, try coke or baking soda, some times people use dialectic grease.
