Sponsored by: CARiD
Rear Diff. Flush?
Old Dec 18, 2006 | 02:06 PM
dailydriver's Avatar
Originally Posted by 98ws61le
for 99+ you do not need the additive
Actually, for the 2000+ Torsens you don't need the additive (unless you get the "rusty screw" sound). The '98-'99 Auburns absolutely need the friction modifier to work properly. This is given one still has the stock diff installed, of course.
Old Dec 18, 2006 | 04:16 PM
01WS6er's Avatar
I just installed new axle bearing/seals in mine. I used 2 qts of RP oil and a rear end gskt. Total for all was about $60 . I do not know what they charge me for the oil, but it musta been free. LOL. I know the bearing and seals was about $45.
With the torsion no additive is needed. I put one in my truck and only used dyno oil for it and it is smooth as glass.
Old Dec 19, 2006 | 09:26 PM
Kalgorn's Avatar
Damn... now I have to actually hit up a dealership for the slip additive? Bastards. That is too much effort for me. Looks like I'll be stopping on my lunch hour tomorrow.
Old Dec 19, 2006 | 09:30 PM
99corvette's Avatar
yep $7.99
Old Dec 19, 2006 | 09:43 PM
Kalgorn's Avatar
That's not terrible. I just hope they have it on hand when I go. Am I just asking for limited slip additive for a '99 Camaro?
Old Dec 19, 2006 | 10:15 PM
99corvette's Avatar
yep, i just told them i wanted rear diff. LSD additive. They told me i didnt need it, and i told them i didnt care and that i wanted it my car.
Old Dec 19, 2006 | 10:47 PM
jattgunman's Avatar
how often should you change the rear diff oil?
Old Dec 19, 2006 | 11:13 PM
sandro arellano's Avatar
yeah, i went synthetic fluid when i did my rear diff fluid change and it was very quiet but when i added the lsd fluid it was even quieter...worth the 8 bucks to me.,.. i changed mine about every 20k
dont really need to do it that much though, just for my own peace of mind
Old Dec 20, 2006 | 11:52 AM
Kalgorn's Avatar
Mmk. I'll be getting the LSD additive soon. Do you put the additive in first and then fill it with the gear oil? I would assume the whole bottle of LSD additive should be in there, right?
Old Dec 20, 2006 | 11:58 AM
01WS6er's Avatar
Put the additive in there first and then fill w/fluid.
Old Dec 20, 2006 | 06:46 PM
  #32
99corvette's Avatar
Check this site out kaldorn, its badass. i believe its got a how-to on the rear diff. flush...... www.installuniversity.com click on install doc.
Old Dec 20, 2006 | 06:58 PM
  #33
Kalgorn's Avatar
You rock.
Old Dec 20, 2006 | 07:34 PM
  #34
99corvette's Avatar
yeah i thought it was a sweet web site, a lot of stuff i want to do to my car is on there.
Old Dec 20, 2006 | 11:48 PM
  #35
LebaneseShowoff's Avatar
i <3 that site, i'm gonna visit it every day now.
Old Dec 21, 2006 | 12:17 AM
  #36
99corvette's Avatar
LOL me too, ive done read everything on that site. I just like how detailed it is and how clear the pictures are.
Old Dec 21, 2006 | 02:46 PM
  #37
98ws61le's Avatar
im have to nicely disagree with you on one point 1999 was the first year of the Zexel-Torsen from factory........ also at that point the y2y option by slp changed from the Zexel-Torsen HD to the Aurburn Pro
"The old disc-type limited slip differential (Auburn) was replaced with a Zexel-Torsen torque sensing limited slip differential. The new differential requires the use of synthetic differential fluid because of its design. The slip-limiting uses metal-to-metal contact inside the case and thus requires the use of the more "slippery" synthetic lubricant." quote from http://tech.firebirdv6.com/general.html
[url] http://www.epinions.com/auto_Make-1999_Chevrolet_Camaro/display_~full_specs [url]
Old Dec 22, 2006 | 11:57 AM
  #38
I may be wrong, but I distinctly remember getting the factory brochure with the exclusive changes to the 2000s. The first thing mentioned was the change to the Zexel Torsen diff. Maybe you're calling it a '99 model year change because they were released in the fall of '99??
Yes, I know about the Auburn Pro, but that was only available from SLP on the SSes and Firehawks, as an option .
