Change oil light.
Here's an excerpt from This Site about oil change lights...
"Those indicators, at least as installed on GM vehicles, don't actually run tests on the engine oil. Instead, engineers program the computer with a lifespan for the oil under ideal circumstances. This ideal scenario varies from one engine to the next, as some engines are harder on oil than others. Then the computer "penalizes" the longevity of the oil based on service. GM believes the most critical external factors to oil life are its running time and its operating temperature; therefore, the indicator tracks engine rpm as a measure of running time and engine temperature as a measure of the oil's environment, applies mathematical penalties to the ideal scenario based on these readings, and blinks the light when the countdown hits zero."
