Sponsored by: CARiD
HVAC/fan motor not functioning
Old Dec 18, 2006 | 02:17 PM
dailydriver's Avatar
Default HVAC/fan motor not functioning
The search showed nothing on this. Before I go to the pain/bother of finding/using a Tech 2, I want to make sure there are NO other fuses/relays/breakers I may have missed checking. Besides the obvious dash fuse panel, are there any others having to do with the HVAC system or fan motor?? I replaced EVERY one of the dash fuses. I have a stripper/no option car so I don't have traction control, electric seats/mirrors/antenna, or rear window defroster. I suspect a ground/fuse/breaker as I don't even get the HVAC control panel lit up with the headlights on. Any ideas?? Thanks in advance. BTW; this is probably due to the f**** that ripped my radio/head unit out/off last week. Does the radio share any grounds with the HVAC system?
Old Dec 19, 2006 | 12:07 PM
ANYONE??
Also, does Pep Boys have the ability to test the fan motor relay so I don't have to waste $35.00 on that (since electrical $h!t is non-returnable)???
