Sponsored by: CARiD
car not starting?????
Old Dec 18, 2006 | 03:25 PM
O-townLS1's Avatar
Default car not starting?????
99 TA. lock cyl. has been replaced, ignition switch has been replaced, vats have been relinked. im running out of ideas and cash. i can be cruising down the road and the car just shut off. all the lights will stay on and the radio and everything but the motor itself shuts off. ill pull over and push it to park (A4) and turn the key. the motor turns over but doesnt crank. just keeps turning over and over and over but wont crank. after a little while it will eventually crank and be ok for a little while then it will do it again. i cant figure it out and neither can the local pontiac dealer, or a few other local shops. anyone have this happen or know wats goin on? i would greatly appreciate u saving me alot of time and money
TIA,
Kody
Old Dec 18, 2006 | 06:12 PM
O-townLS1's Avatar
anyone?
Old Dec 18, 2006 | 06:14 PM
bastien's Avatar
it's probably fuel related.
Old Dec 18, 2006 | 06:22 PM
2001NBMZ28's Avatar
I'm thinking along the same line - might be fuel related. Did the dealership/shops check fuel pressure, replace the filter? Second guess would be the battery/connections but seems wouldn't be the case if it's turning over normal.
Old Dec 18, 2006 | 06:49 PM
O-townLS1's Avatar
fuel filter was replaced a couple months ago but no they havent checked anything fuel related. first time it happend around 3 months ago before i took it to the shop i talked to a few friends that are mechanics and they sed it could be the fuel pump or fuel relay. wen u turn the key to the on position and get behind the car u can hear the fuel pump so i wouldnt think it was that. the fuel relay under the hood has been replaced. ive spent probly $1500 on trying to get this fixed and nothing has seem to do the trick yet and im running out of funds and time being that im in school and this is the car i rely on every day. and no they didnt check the fuel pressure. could it be a bad regulator?
Old Dec 18, 2006 | 07:00 PM
bastien's Avatar
hmm, sorry I can't help you then :/
perhaps you should try posting this in the fueling & injection section!
Old Dec 18, 2006 | 07:06 PM
O-townLS1's Avatar
well the reason i posted it here is because i wasnt sure if it was a fuel problem or not nor am i totally sure now.
