Sponsored by: CARiD
Misfires?
Old Dec 28, 2006 | 03:34 PM
01SOMm6's Avatar
Default Misfires?
So this problem has been bugging me for the longest time(7 months). WOT the car seems to miss and it shakes back and forth. So I figured it was either spark or fuel?? So Im under the hood looking around and notice theres sparks coming from a connector that is connected to all 4 coil packs on the passenger side. I take off each coil pack and notice one is corroded and change it with a new one. I also put in new tr55 plugs and msd wires. I still have the problem. I also changed the fuel filter but still no luck. I even switched to a differant maf sensor and still missing! Anyone have any ideas? Could the connector that I seen sparks coming from have gone bad, maybe I damaged a spark plug or something?
Had someone from sct ride around with me before and all we could pick up was random missfires.
Old Dec 28, 2006 | 05:12 PM
01SOMm6's Avatar
Anybody???
Old Dec 28, 2006 | 09:38 PM
MdFormula350's Avatar
sounds like its sparking / arching at that spot instead of the tip on the spark plug, i would switch that area with another wire and plug from any other cyclinder and see what happens.
also check for any lose ground wires in that area if any.
Old Jan 3, 2007 | 10:02 PM
m_ghonim's Avatar
What I seem to hear is that MSD does not work well with the ls1. Use only dealer spark plugs!
