Sponsored by: CARiD
Battery is pulling 185 mA when off. Why?
Old Jan 12, 2007 | 11:06 PM
01WS6er's Avatar
I have seen alternators do wierd stuff as you say the mA keeps fluctuating. Let us know what the dealer finds.
Old Jan 13, 2007 | 11:25 AM
HotRodNeil's Avatar
Well, the Sony aftermarket radio was damaged when he went into a ditch (MB cracked) and this killed the backup battery in the radio for the settings. Therefore, the radio got it's power from the car, 185 milliamps. When we pulled the fuses, we forgot the spike current that the PDM pulls for 20 seconds until it levels off. If we had left the battery connected using a clamp on meter instead, we would have found it immediately, but I only had my regular amp meter that goes in the circuit. My son's pissed he had to pay $300, but he learned a lesson.
Thanks everyone for your help.
HotRodNeil
Old Jan 13, 2007 | 02:01 PM
HotRodNeil's Avatar
We took it to the dealer and found that the aftermarket Sony Radio was pulling the 180ma due to a dead backup radio battery. What threw us off is that the PCM pulls 300ma for a few seconds and then drops back down, and we didn't notice that until we pulled the other fuses.
It cost my son $300 to fix this, but hopefully, he learned something!
Old Jan 15, 2007 | 07:31 PM
Sneakyws6's Avatar
On the tree
My bird does this same thing though it is more along the lines of 1 week before the battery dies.
What do you do to test how may amps the system is drawing?
Old Jan 16, 2007 | 01:06 PM
HotRodNeil's Avatar
My car draws 8 milliamps under normal drain with the car off (no aftermarket accessories). I suggest hooking up the amp meter, and start pulling fuses until it drops. How many milliamps is it drawing now? The normal culprits are the dome lights, radar detector, radio, or almost always an aftermarket install.
I'm going to get a DC clamp meter UEI ACM6000 to measure the current when the wires split. It makes life easy!!
BTW, you remove the plus red wire from the battery and hook up the ampmeter in between the red and the battery, with a heavy duty clamp. Pull a fuse and look at the meter,, do this one by one.
Remember than when you hook up the meter, the PCM will draw 300 mA for a few seconds and then will drop down. Don't rush this or you will get an incorrect reading.
Old Jan 16, 2007 | 08:01 PM
Sneakyws6's Avatar
On the tree
Thanks for the info...
Found out last night and was verfied today that I had a bad Optima Red top battery. Mine had a bad cel in it. Sears replaced it for free and I am off and running again.
