Sponsored by: CARiD
100k mile tuneup
Old Jan 11, 2007 | 01:12 PM
SVT THIS's Avatar
Default 100k mile tuneup
I am about to hit the 100k mark and was wondering what I should do as a tune up? I've already got new plugs and injectors, so I was thinking...
New shocks/struts (whichever these use)
Recharge AC
Fuel filter/oil filter
Tranny flush
What else would you all do?
Old Jan 11, 2007 | 02:29 PM
Spink's Avatar
Check Belts
Change differential fluid
Flush and fill coolant
Seafoam
Old Jan 11, 2007 | 02:55 PM
04gtoBMXracer's Avatar
seafoam??????? are you serious?
Old Jan 11, 2007 | 03:09 PM
NVR KNO's Avatar
shoot, if she is still kicking fine once she hits the 100k mile mark. keep on trucking, i wouldnt worry about. if you start flushing everything, she might start messing up. especially an engine flush, ive never seen good things come from that.
Old Jan 11, 2007 | 03:15 PM
Starz T/A 17's Avatar
I bought my car with 116K on it and flushed ALL the fuilds and did all the basic tune up stuff (plugs,wires, PVC, fuel filter, air filter, exc) and it runs as good as my 60k and 75k ls1 cars that I had before
Old Jan 11, 2007 | 03:21 PM
Spink's Avatar
Why not?
Old Jan 11, 2007 | 03:56 PM
bjamick's Avatar
Also radiator flush. I would do a huge engine bay cleaning and painting. Spark plugs, maybe some new plug wires, Then i would do a complete sea foaming.
Old Jan 11, 2007 | 04:09 PM
NVR KNO's Avatar
ive never heard of seafoaming before, what is it?
Old Jan 11, 2007 | 04:14 PM
Sharpe's Avatar
See the sticky in the General Maintenance & Repairs thread.
https://ls1tech.com/forums/general-maintenance-repairs/534376-how-seafoam-your-car.html
Great write up by ChocoTaco369.
Old Jan 11, 2007 | 05:12 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
100K mile maintenance depends on what you've done so far and when the last time you did certain things was. For example, if you just changed the plugs at 90K, there's no point in doing again at 100K...., etc.
Originally Posted by SVT THIS
Tranny flush
Be careful with this one. If your trans fluid has never been changed in 100K, you might cause more problems than good if you flush it now.
Old Jan 11, 2007 | 06:02 PM
BLKWS.6's Avatar
DO NOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Do a tranny flush. You wont leave the shop and that is a 50/50 odd right there. The new fluid has a lot stronger detergents than the worn out fluid and will wipe all the varnish off of things and you will have a slipping tranny in NO TIME.
Engine flush...dont do it. You will most likely wipe the varnish off the bottom of the pan and clog the oil pick-up tube.
I know on my 170K mile LT1 just running shell rotella 15-40 filled my oil filter with jello like crap every 3-500 miles until it was all flushed out, I cant imaging what I would have stopped up with an engine flush!
Old Jan 11, 2007 | 06:04 PM
BLKWS.6's Avatar
On a manual tranny a fluid change is okay. I just did mine at 76K miles and it shifted notchy for a few hundred miles and now its doing great
Auto tranny...if it hasnt been changed every 15-20K miles, DO NOT DO IT! EVER!! If the fluid isnt dark, its okay, if it is dark, its beyond help. Just leave it be! It will thank you by not crapping out and slipping 10 miles after your new fluid rips all the old, varnished clutches apart.
Old Jan 12, 2007 | 08:48 AM
98ws61le's Avatar
not being an a$$ but preventive maintenance starts at 0 miles
Old Jan 14, 2007 | 12:29 PM
Ahmadi6490's Avatar
What's the main purpose of the PVC valve and why's it needed to replace?
Old Jan 14, 2007 | 12:49 PM
RPM WS6's Avatar
To vent crankcase vapors/pressure. Instead of releasing the fumes into the atmosphere, the OEMs use PCV systems to vent these vapors back into the intake system to be burned off with the rest of the intake charge.
The valves need replacing from time to time because they get gumed up with oil vapor, etc. It's an extremely cheap part. Maybe $7 from a dealer or less from a chain parts store.
Old Jan 14, 2007 | 01:07 PM
Ahmadi6490's Avatar
Oh so its another thing for better mpg? Because i'm only getting 21 in the city.
Btw, didnt mean to jack this thread.
Old Jan 14, 2007 | 01:34 PM
RPM WS6's Avatar
Not really MPG. Just to keep crankcase pressure from damaging seals/gaskets, and to release water/oil vapor from the inside the motor.
21mpg in the city isn't bad. I only get about 19-20 in the city with my 3.8L V6s in my Monte and Bonneville.
