Sponsored by: CARiD
View Poll Results: Flush Tranny fluid or no?
Yes
29
67.44%
No
14
32.56%
Voters: 43. You may not vote on this poll
To flush or not to flush?
Old Jan 13, 2007 | 06:18 PM
  #41
ricardo colon's Avatar
nobody said anything about additives for the transmission ,like transguard
Old Jan 13, 2007 | 09:22 PM
  #42
Tainted's Avatar
Originally Posted by subtlez28
Your tranny failed because of the condition that burned your fluid in the 1st place. Its crazy to blame the flushing. Its like blaming washing your car for a mechanical failure. How on earth would it be benificial to leave compromised fluid in a tranny?
Would you say, my rear end weas grinding and popping. So I changed the gear lube. 500 miles later the rear end gave up....damn new gear lube.
Flushing will not move anything that isn't already moving w the tranny operating. Autos have a pump built in, they operate at pressure. Flushing is used to get more of he fluid out of the trans since it doesn't all come out the pan(alot is trapped in the converter and elsewhere). It is not to pressure wash the inside or anything--just to get more of the actual fluid changed out.
DO NOT FEAR THIS BASIC MAINTENANCE PROCEEDURE!
*Thant being said--don't let a shop (Jiffy Lube or other quick oil change places) flush w/out dropping the pan and changing the filter...that is a $ maker 4 them that is a gimmick. You wouldn't change your engine oil w out changing the filter would you?
see thats exactly the way I was thinknig about it. and yea my fluid actually looks pretty good so im gonna drop the pan change the filter and fill it back up and call it a day and move on with the other maintence things
Old Jan 14, 2007 | 10:49 PM
  #43
MEZA TA's Avatar
Go for it.....I did the flush and filter on mine when it had 95k and 2 weeks later 2nd and 3rd gear where gone on my A4. Had to buy a new tranny cause apparently it was cheaper to replace than repair. Like you've heard already theres arguments on from both sides. I just don't have $1,300 to spare for a new tranny so i'm holding off on any trans flushes for now.
Old Jan 14, 2007 | 11:37 PM
  #44
Tainted's Avatar
well im gonna take a swing at it and replace the filter and the fluid thats in the pan
Old Jan 14, 2007 | 11:58 PM
  #45
NDFORSPD's Avatar
Originally Posted by RPM WS6
Depends on who rebuilds it.
Try driving a new stock 4L60E, then drive a 4L60E that was built by Chuck at FLT. You'll like the 'rebuilt' one better, I promise.
Yeah the thing Is ive had only to rebuild on 2 gms (both V6s) and they always drive like ****. Like my GTP now will drive and shift ok, but if im in reg traffic, it'll want to seek the lowest RPM/Gear it can go into just after 70kph and then its doin 1250-1300rpm and boggs. The thing is I know for sure it never did it when the orig. tranny was in, it felt fairly smooth. But yeah your right Id have to try another shop.....lol or i'll stick to the M6ers
"Your tranny failed because of the condition that burned your fluid in the 1st place. Its crazy to blame the flushing. Its like blaming washing your car for a mechanical failure. How on earth would it be benificial to leave compromised fluid in a tranny?"
Yeah I didnt check the fluid when I bought the car (so good knows what the guy before me did ) and I let it go for about 6-8 months and it got worse, I didnt have much faith in the tranny in the first place to be honest. You could almost see it getting darker from month to month. They are known to crap out at lower milage(the 4th gear was demoed). But yeah I figure the guy before me had probably driven it hard since he bought it. But the trans def. did not like the flush at all, shifted wierd, especially in the winter cold(when it got warm it drove better), but i wouldnt personally flush a high milage tranny, unless proper service has been done.
Old Jan 15, 2007 | 08:20 AM
  #46
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Sounds exactly like what my old Toyota did after a higher mileage first time flush.
Old Jan 15, 2007 | 11:32 AM
  #47
Gun5's Avatar
What about if i have a new tranny? I planned on doing filter/fluid every 9k or seomthing is the reasonable? even 10k? its a John Goebel 4l60e
Old Jan 15, 2007 | 01:22 PM
  #48
mach2004's Avatar
As a former Service Manager of a dealership, change the fluid.
Old Jan 15, 2007 | 04:32 PM
  #49
Tainted's Avatar
any recommendations of a fitler or will just any generic nappa filter do?
Old Jan 15, 2007 | 04:49 PM
  #50
joecar's Avatar
This is what I do...
https://ls1tech.com/forums/showpost....1&postcount=10
Old Jan 15, 2007 | 06:35 PM
  #51
joecar's Avatar
I use the ATP filter kit because I like the black felt/fiber gasket (it expands when wet to seal up any leaks) that comes with it.
Old Jan 15, 2007 | 07:14 PM
  #52
Tainted's Avatar
mmk ATP ill prolly try that then
Old Jan 15, 2007 | 08:07 PM
  #53
joecar's Avatar
http://www.rockauto.com/catalog/rafr...126&a=FR4-B126
Old Jan 16, 2007 | 05:33 PM
  #54
toofless916's Avatar
i have an A4 with 64,000..dont know if its ever been changed picked it up when it had 32,000 on it...60k is about the time tranny flush should be done?
Old Jan 16, 2007 | 07:04 PM
  #55
Tainted's Avatar
it SHOULD be flushed every 15k. if you want take a chance and change it thats what im doing. if its so fucked up that a siemple maintence procedure "hurts" it it needed to be changed anyhow
Old Jan 16, 2007 | 08:30 PM
  #56
yea i dunno...i might flush it cuz i dude that had it before me picked up an extended warranty so if anything starts acting up imma have em fix it or replace it...just remembered that right now actually...
Old Jan 16, 2007 | 09:06 PM
  #57
Tainted's Avatar
go for it then, you got nothing to loose
Old Jan 17, 2007 | 09:41 AM
  #58
irnbru83's Avatar
Mine has 70k on it and seeing this thread is making me cringe. I have no idea if the previous owner looked after the transmission or not. i guess i'll pull the dipstick and have a look.
Old Jan 17, 2007 | 10:12 AM
  #59
BitViper's Avatar
Ive got 50K on minw ans I changed teh fluid in BOTH the Diff and Tranny...
The car now , M6, accelerates better smoother, shifts better...
The middle ground heer is to NOT flush but to just change the fluid and filter. The advantage to flushing is that you cag go to a completely diffrent fluid...changing is just that..you replace the fluid with the exact type and clean the filter
Old Jan 17, 2007 | 03:37 PM
  #60
joecar's Avatar
Problem with an A4 is that if you just pull the pan off, 4 quarts fall out, while the torque converter still retains 8 quarts (and also the cooler retains a quart).
