Cold morning starts...
Brand new Duralast battery... alternator was replaced 2 months ago.
If i rev it up to 4-5k for a few seconds, the battery voltage will jump up to 15V.
Not sure what the heck is going on, but I guess I'll go to Autozone and get the new battery tested just to be sure it's holding a charge properly.
And yes, I mean it's only showing 10V in cold weather, the lights are dim, etc. It won't rise until i nail the gas for a few seconds... which is relatively dangerous if you are driving in the wet haha
Alternator on the first run on the machine performed poorly. The battery sat at 11v and would not charge past that (running at 2k rpms while test is going on).
Second test (1 minute later), battery suddenly starts getting charged and runs up to 14.5v while running car at 2k rpms.
Soooooo first run alternator was crap, second run it worked great. Only problem I've had with alternators was total failure (0 output current) and low output current. I've never heard of one having low current, then high current. Loose wire somewhere???
