Sponsored by: CARiD
installing an adjustable panhard rod
Old Feb 3, 2007 | 01:57 PM
LS1ne's Avatar
Default installing an adjustable panhard rod
ok folks heres the short long story, my passenger side rear wheel seems "tucked" under the fender abit more than the drivers side wheel. From extensive searching I think my rearend shifted to the drivers's side(left). I bought an adjustable panhard rod, now question is which way do I install the panhard to correct my problem? Threaded side 2 the drivers side or passenger side? thanks
Old Feb 4, 2007 | 02:44 PM
3.4camaro's Avatar
doesnt matter. its a bar. install it so its easiest to adjust when on the car.
Old Feb 5, 2007 | 10:20 PM
kdoublep's Avatar
I use an edelbrock adjustable phb and their instructions said threaded part on driver's side.
Old Feb 6, 2007 | 10:06 PM
Flawless02SS's Avatar
Is the panhard rod single or double adjustable? If its single, its going to be a bitch by yourself to get it back lined up. You will need a buddy to push on the rear end while you try to get the bolt back through. Being single adj. you have to thread it a little and test fit it. On the other hand, if you have a double adj., you can fully install in on the car and thread it th eway you need to. Much easier, but they cost more.
