Sponsored by: CARiD
90k tune up?
Old Feb 7, 2007 | 12:12 PM
Ace$nyper's Avatar
Default 90k tune up?
Last night I just turned over 90k.
I am wondering oil fuel and air filter are fresh anything I should look into or be ready to do ? Coolant was done last year same with rear fuild.
Car is a 99 z28 m6.
Old Feb 7, 2007 | 05:39 PM
01SSRMS's Avatar
You could do a drain and fill of the tranny. Also, flushing the brake fluid through with fresh would not be a bad idea on a 99 with 90k. Coolant hoses are probably fine, but give them a squeeze and see if you feel any cracking on the inside. <you'll know if you feel it. Spark plugs still original? Definitely due for those. Put in some NGK's. Other than that, make sure everything is topped off and such and you're good to go. One other thing I always do when doing maintenance is lube my door hinges and latches, hood hinges and latches, wiper arm pivots, and rear hatch pivots.
Old Feb 7, 2007 | 06:17 PM
Tainted's Avatar
tranny fluid, oil air filter cleaning or new one, plugs, wires, fuel filter, seafoam
Old Feb 7, 2007 | 09:23 PM
Ace$nyper's Avatar
Thank you both much
