Sponsored by: CARiD
Cluster won't work??? HELP
Old Feb 16, 2007 | 02:02 PM
stroked383z's Avatar
Default Cluster won't work??? HELP
I purchased a cluster off of another LS1Tech member 99Z28camaroman , cause they had white faces, and blue bulbs. After getting it, I removed my working cluster and installed the one I purchased, and alot of the gauges on the new one will not work??? The speedo, tach, mileage will not work, the battery, oil, temp, gas do work??? I can put my original cluster back in and it will work fine??? I'm stumped!!! What can I do??? Reset the computer??? Take to the dealer??? My car is a 2002 Z, and he said the cluster came out of his 1999 Z.
Old Feb 16, 2007 | 02:03 PM
staringback05's Avatar
if you can put the original cluster in and it works fine and you follow the same steps when putting the other one in..........that aftermarket cluster is the problem
