gm top end cleaner
<small>[ August 12, 2002, 01:35 AM: Message edited by: hondakiller ]</small>
Get the spray can, it's a little easier to administer. Just pull the lid and maf out of the way, but still leave everything plugged in so the car will hold a normal idle. With the TB exposed, slowly spray the cleaner on the bottom lip of the TB and just let the car sip it up while idling. Spray until the can is gone, then put everything back in place. Most recommend you let the car sit for about 4-6 hrs so the cleaner can soak. After the car sits, take it out for some "spirited" driving. Your car will smoke like a freight train at first, but that is fine. The more smoke the better. Good luck
Josh
Dope
I want to do this on my 99 Tahoe, it's got...
107K on it. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I think it pings on part throttle.
<strong>well i got a can of the liquid because the two dealers i went to said they didnt carry the spray stuff anymore. i dont have to worry about hydrolock do i? as long as i follow the directions?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No - you cant hydrolock the engine cause you wont have any plugs in the block - thus when you turn it over that stuff will squirt for miles! HAHA! Have fun...
Shane
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> I felt it necessary to fill you all in on how to de-carbon your engines. Here is the reason. For most all situations, knock on a stock c5 will be due to carbon buildup, plain and simple. While there is a lot of speculation, fact is that out of 51 different c5 that I have performed this procedure, NONE have returned. There will always be the occasional one that this may NOT apply to, but for the most part, it should work. Also, just a side note, if your c5 is modified, even with just a MAF, this may not work, due to other issues, so do not ASSUME that this is a fix all.
Okay, first thing, go down to your GM dealer and purchase 2 cans of liquid top engine cleaner #1050002. That’s the part number. And get oil and filter, as you will have to change the oil after this procedure.
Second, let the car sit until it gets cold before you start this procedure.
Now, are you ready???? First, remove all spark plugs.
Next, evenly divide the 2 cans to feed 8 cylinders.
Remember that this will get messy, so have plenty of rags around, and put something under your car, and not all the cylinders will take all the chemical.
Next, add the cleaner to each cylinder, some may pour out, and some may take all of it. I leave rags under each plughole.
Then, pop a cold one because the cleaner must sit at least 6 hours, I like to see 12, but at least 6 are the minimum.
The next morning or whatever put a bunch of rags over all the plugholes, as you must crank over the engine to expel the entire cleaner. It’s going to leave a mess, so be warned. Crank over then engine for about 15 seconds, that’s all it takes. Clean up all the residual off the manifolds, with brake cleaner or something. Install the plugs.
Roll the vehicle outside, cause MAN is this going to smoke, and stink. Start it up, it will run rough for a while, this is common, and it will smoke too. Allow to idle for 20 mins. Then shut the engine down, and change the oil and filter.
The cleaner dilutes the oil so we don’t want to drive the car until after all has been consumed in the chamber, and the oil is warm.
Ok, now for the test drive, go to a highway, and drive a highway speeds for about 20 mins, to expel the cleaner from the exhaust. The car WILL smoke for some of the test drive, this is NORMAL. But by the time that you get back, it should be pretty much gone.
Ok, that’s it. Just remember, this is informational, nothing more. You may get some oxygen codes or some misfire until the cleaner is burned off, this is NORMAL. Just reset the codes, and you will be fine.
I have had a lot of success with this, as have some of the members that I have emailed this process to, but you must follow it exactly, thanks.
Best to all, and I remain, c4c5 specialist
c4c5mechanic, GM certified in all areas. ASE master certification w/L1. Club Corvette of CT member.
I just wonder what the dif is between the spray and the liquid. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
