Sponsored by: CARiD
E-brake adjustment???
Old Mar 5, 2007 | 06:35 PM
b4ckid02's Avatar
Default E-brake adjustment???
i have a 2002 camaro and i was wondering how to adjust the E-brake...i took the center consol apart thinking the adjustment coud be done there but obviously not. Iam sure the adjusment is done underneath the car but i was wondering if anyone had any tips or anything to help me out cuz i dont want to **** **** up...thanks
Old Mar 5, 2007 | 07:03 PM
2001NBMZ28's Avatar
Supposedly just cycling the ebrake slowly three times adjusts it according to helms. How many clicks you getting before it holds?
Old Mar 5, 2007 | 09:46 PM
Sneakyws6's Avatar
On the tree
No cycling it slowly will not do anything.
The adjusters are in the rear on each side of the rotors. Remove the caliper one side at a time. Then remove the rotor. On the bottom of the rotor backing plate is the adjuster.
When I adjust mine I set the ebrake to 4 clicks and then adjust the adjuster until that 4 clicks holds the rotor in place. Then I put that side back together and do the same for the other side.
Once both are done I make sure the 4 clicks holds both sides then make sure the car will not roll once it is back together.
Old Mar 6, 2007 | 04:34 PM
b4ckid02's Avatar
thank you
