Sponsored by: CARiD
daytime runing light and blinker issue
Old Mar 7, 2007 | 06:27 PM
cvalliere's Avatar
Default daytime runing light and blinker issue
So I took my 2000 SS to the muffler shop the other day and when I turned on the left blinker it didnt blink. When I got to the shop I checked the bulbs and they looked fine, then I noticed the left front daytime running light wasnt on. I turned on the parking lights and it lit up but still no blinky. When I got it back home I took out the left front bulb and repaced it with a new one, nothing. So, I took a test light the socket and I got no power to the socket until I turned on the parking lights. I have no idea where to start looking. Anybody have any ideas?
Old Mar 7, 2007 | 06:41 PM
nprather's Avatar
common f body issue!
Old Mar 17, 2007 | 01:19 AM
somws6bird's Avatar
I almost have the same problem but the thing with my car is my daytime running lights are fine, its just my blinkers that dont work. Thell be working fine then stop working after then start again. When I put my signal on as Im turning they don't go on. My rear break lights don't work either, its totally random when the'll work and when they won't.
I was told to change the multifunction switch. Im not completely positive that this is what you need but it could be something to look into. When I change it, Ill let you know the results, Good Luck!
Old Mar 17, 2007 | 01:20 AM
razorclaw99's Avatar
haha SAME! randomly solid green arrow then sometimes it will actually blink
Old Mar 17, 2007 | 01:23 AM
96blkformula's Avatar
i had the same problem with my formula when i got it and my blinkers wouldnt blink but when i turn my flashers on it did so if u have that then u need to take the panel under the steering wheel off and change out the flasher for the blinkers...hope this helps!
