Sponsored by: CARiD
Removing wire on alt
Old Mar 8, 2007 | 12:44 PM
clayton02LS1's Avatar
Default Removing wire on alt
Is there a trick to getting this out? Like is there a push tab or something or just it just pop out with some prodding? Thanks
Old Mar 8, 2007 | 01:11 PM
tim99ws6's Avatar
To say the least, its a PITA. I have had the best luck with unbolting the alternator, gimmying it up a bit, and to a better position to get to it, and then getting it out. I always grab the smallest flat head screwdriver i can, as the connector is sorta hidden down a bit, and i have big hands.
Good luck with it man!
EDIT-Don't forget you have a ground wire on the bottom of the alternator you have to unbolt as well!!!
Old Mar 8, 2007 | 01:55 PM
Thanks man. Yeah i had to get the alternator out a little and pop it off with a flathead.
