Sponsored by: CARiD
starting problem
Old Mar 17, 2007 | 01:54 PM
utahws6's Avatar
Default starting problem
not sure where to post this.
ive been having problems with my slave leaking...clutch pedal pressure had been pretty much nill..
but in the meantime before i can fix it i have been tryin to make do .
in the meantime it started not starting..
ive had to start it in gear sometimes because of the slave
and the one day i it fired right up and then after i shut off and went to start in gear it wouldnt.
now today for the first time cold..it wont start...
no clicking....or anything from the starter..full power to everything else.
im wondering if it as somethign to do with the clutch lockout to the starter...
(clutch pedal having to be depressed to start)...
i cant find any info anywhere
i did check the starter relay...
