Sponsored by: CARiD
wierd prolblem with dash lights???
Old Mar 21, 2007 | 08:14 PM
Rare99Z's Avatar
Default wierd prolblem with dash lights???
so the past couple times i have taken my 99 z/28 out at night this problem has happened. when i have my headlights on, the instrument lights and radio lights go on as usual. well at least once per night the dash/instrument/radio lights just turn off. all that is lit up is my odometer and the time on my radio. it only stays off for about 20-30 seconds and then it magically lights back up. all my gauges work too when this problem happens, its just the lights. its the wierdest thing and i have no idea whats causing it, any suggestions?
Old Mar 22, 2007 | 01:35 PM
daryl2cb@yahoo.com's Avatar
bad ground somewhere, check to see if you have continuity in the ground circut when they go off. probably under dash near steering column.
Old Mar 22, 2007 | 05:31 PM
3.4camaro's Avatar
also the dimmer may have some dust on it. turn it up and down a couple times.
