Window Motor Questions
Price: between $40 & $60
Other auto parts stores also have them and they typically come with a lifetime warranty.
https://ls1tech.com/forums/showpost....1&postcount=18
There was a discussion of this operation a while back, and someone said that they "Wouldn't butcher their car" by drilling a couple of access holes in the door's inner panel, allowing access to the rivets that hold the motor in place. They chose to go through the agony of unbolting the entire window track assembly, lowering it into the door, and replacing the motor that way.
I used the new motor as a template, carefully determined where the rivets are, drilled two small holes, about 3/8" in diameter in the door's inner panel, and drilled out the motor rivets, leaving the window regulator in place. It wasn't hard at all. Just take your time in locating the rivets
