Sponsored by: CARiD
E-Brake not working
Old Apr 15, 2007 | 11:37 PM
97camarozguy's Avatar
Default E-Brake not working
Just like the title says. When i pull on it, nothing happens. It is probably something simple, but just wondering if anyone would have some input before i start tearing things apart.
Old Apr 16, 2007 | 12:42 AM
68Goatboy's Avatar
adjust the cable ?!
Old Apr 16, 2007 | 09:39 AM
Sneakyws6's Avatar
On the tree
If your car has rear disc the adjuster for the E-brake is in the rear brakes under the rotors...One on each side.
Old Apr 16, 2007 | 09:54 AM
Hugger Z's Avatar
Maybe you broke a cable or something in the lever is not working? Does it sound normal when you pull up on it?
Old Apr 16, 2007 | 12:05 PM
The lever sounds normal when i pull on it. I didn't know that there was an adjustment on the back. I will check that out. Thanks a bunch!
Old Apr 16, 2007 | 02:41 PM
staringback05's Avatar
the ebrake is set up like a drum brake....check the pads...if the cables not the problem
