Sponsored by: CARiD
Coolant in the frame?
Old Apr 19, 2007 | 07:29 PM
ws6andy's Avatar
Default Coolant in the frame?
Just wondering if anyone has ever heard of this. I got my waterpump replaced today, and took it for a spin and stopped at Autozone to get some Armorall...anyways, I came back out and there was a huge puddle of anti-freeze under the car (about the length of my car and a 1-2 feet wide)...the mechanic thinks that it was stuck in the frame from when they took out the waterpump...anyone else heard of this?
Old Apr 19, 2007 | 07:34 PM
96slow6's Avatar
I could see some getting trapped in the k-member. But a big puddle like that would make me wonder. Did you check your fluid level afterwards? Are sure it wasn't there when you pulled up? Did you look to see if there were drips coming from the pump weep hole?
Old Apr 19, 2007 | 07:37 PM
ws6andy's Avatar
it definitely came from my car...the time I got back out it was all done leaking and I couldn't get under it...just took it back to the mechanic right away
Old Apr 19, 2007 | 08:10 PM
96slow6's Avatar
Was the car running when it was leaking or was it turned off?
Old Apr 19, 2007 | 08:17 PM
ws6andy's Avatar
turned off...parked on a slight incline...but also, when I picked the car up from the shop, it was also on an incline that was about the same as Autozone
Old Apr 20, 2007 | 12:23 AM
96slow6's Avatar
Hmmmm. Two things i can think of considering the time. 1) its coming out of the over flow from getting hot or the level in the over flow is to high 2) its coming from the weep hole when you shut it off just enough to drain the impeler cavity. either way you need to get under there and see if you can see were it might be dripping from. Also check your fluid level in the radiator and see how it looks.
Old Apr 20, 2007 | 12:57 AM
LiENUS's Avatar
Passenger side to the back of the engine. You sure its green with coolant and not just clear? If its green its your heater core if its clear its nothing.
Old Apr 20, 2007 | 06:13 AM
ws6andy's Avatar
nope...it was orange...coming more from the passanger side
Old Apr 20, 2007 | 02:05 PM
staringback05's Avatar
did you check the level of the fluid to see if you were missing some?...
if so id be checking the gaskets from the water pump
Old Apr 20, 2007 | 04:55 PM
96slow6's Avatar
Its the over flow i would bet. Check it and the radiator level. If the over flow is empty thats a good sign it boiled over and sucked it back up.
