Sponsored by: CARiD
Castrol 0-30
Old Apr 28, 2007 | 11:39 AM
SIK02SS's Avatar
Originally Posted by WS6store.com
We have it in stock at all times, just an FYI, ships same day ordered
thank you sir
just placed my order
Old May 10, 2007 | 08:18 PM
bursty's Avatar
Another order placed here. Please dont stop carrying this!
Old May 10, 2007 | 10:50 PM
BLK02TA's Avatar
Originally Posted by INMY01TA
Not discontinued, Autozones are just not stocking it anymore. I believe the WS6 Store sells it online. More info.
I just bought some yesterday at the local autozone. Not sure where you got that info from? Could have been the last they had?
Old May 11, 2007 | 07:57 AM
Weezzer's Avatar
Originally Posted by JimsWS6
Wouldn't it be better to run 5w-30? I know the first number is it's weight cold, and the 2nd number when hott. But I know 5 vs 0, 5 would be alittle thicker when hott right?
No, this is incorrect. The cold rating has nothing to do with the thickness when its hot.
I didn't realize the GC was getting hard to find. Glad I've got 50 qts of it on my shelf.
The old GC was green and was made in Germany, the new GC is golden and is made in Belgium, thou it still says "Made in Germany" on the back.
The old formulation (green) ends with MO501XXXX, the gold version begins with stock number MO502XXXXX if I recall correctly. This number is usually found on the bottom of the bottle. If it says its the European Formula on the front - then its the gold version. The gold version seems to be just as good as the green if not better - judging by the recent UO analysis of it posted at bobistheoilguy.com.
Old May 11, 2007 | 08:10 AM
Weezzer's Avatar
Originally Posted by Redlinez
The 0-30 is the only one made in Germany. Some Autozones still have it. You might want to have that store locate you some and order it in.
You don't want to order a case from Autozone, they can't tell you till it arrives weather its the American version (not the same formulation and not a full synthetic) or if its the German/Belgium formulation.
They put the same SKU number on both, as far as they are concerned its the same 0W-30 oil. If it doesn't say "Made in Germany" on the back you don't really want it.
Old May 11, 2007 | 09:29 AM
98ws61le's Avatar
i have about 80 qts in the garsge back when AZ was selling them at 4 bucks per
Old May 11, 2007 | 10:21 AM
Mr Incredible's Avatar
Please review the list of oil viscosities I have placed. Save it to your desktop for easy reference later.
If it makes you actually think, then you can follow up your thoughts at http://theoildrop.server101.com
GC is still being made. Some AZ's aren't carrying it any more. Some do. Some have it all the time. Some have it some of the time. Some will have it soon. Others will be out soon. Keep checking as long as you still care and you may find it. Buy extra if they have it.
GC is awesome because it is an actual full synthetic oil of the highest quality. LS1s like it. LS1s like other oils, too. Try several to find one that suits your own engine/driving habits/local purchasing requirements.
