O2's got wet. What to do?
Try to reset your computer by disconnecting the battery for 30 minutes. Do this a second time if the SES light comes back on and if that doesn't fix it you'll need some new O2's. Make sure the electrical connections check out too before you pitch them.
https://ls1tech.com/forums/automatic-transmission/706109-sportline-springs-rain-wet-tranny.html
i will try resetting the battery tomorrow to see if that fixes it. one of the O2s is a new bosch and the other is just the factory O2 with an extension (i've got an x-pipe with duals). The car ran fine tonite but started to bog down again when i got home. the guys at my shop were like yeah it's just wet O2s let 'em dry. they said sometimes it takes a long time? what?
If it got on your electrical components this could be an issue as far as corrosion and the like nothing serious. Water in or on high voltage items like coils and wires is always a problem (i.e. arcing, shorting) and 'NO' water CAN stay trapped in things like weather-pak connectors and spark plug wire boots for a long time especially in cooler 'RAINY' climates. Which is why I recomend you try and pull codes. I know the answer lies somewhere in your PCM's memory.
i'll get the car scanned first thing in the morn.
