Cracked interior door panel...:( *DON'T QUOTE PICS!
Originally Posted by nasty99WS6
I have SFC on my car, and it still happened.
Question for all those that have this problem - which side of the car did it first occur on?
SFC will not prevent this, just because the way the door is loaded and stressed even with SFC.
The only common point here is the way the window causes a inward stress on the door and the panel, when the motor drives it to the full down position. Over,over,over,over, in the exact same spot.
Now weather it be from the position of the window within its track or the torque of the motor, when driven full down needs to be determined.
I have not had my panels off, so I have not looked into the inner structure of the door.But I have made it a conscious effort to not let the windows drive to there full down position, (even with the seal) not below. With no cracking, or damage at 43k.
Originally Posted by 785T/A
Mine is cracked, same thing happened
http://i22.photobucket.com/albums/b3...ers/car005.jpg
>>>NO NEED TO QUOTE PICS!!!<<<
Waiting for Classic Industries to come out with a replacement panel someday.
BTW, I have NO SFC's and race all the time been racing since it's had 6K on it, now I have 70K. This is a recent thing for me maybe a few weeks, not so bad considering the car is a FL car and is outside in the heat and has been for 5 yrs now.
01ls1lover my crack is the same as yours
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Now on a more serious matter I had the same problem. It started over the passenger side then moved to the drivers side. I got lucky and found two nice panels off ebay. When I took the old ones out I examined the structure behind it. They were both cracked at the exact same spot just lateral to a small plastic rib. Apparently this is a factory defect. Since these panels are so long they get bent at this point when the window is rolled down all the way. Think of when you take a credit card and bend it to the point it just splits in two.
The ones I got form ebay I reinforced them with pieces of hard rubber behind were the cracks appeared. Also i don't rolled windows down all the way. Hope these two last for a long time!!
You said yours showed up on the passenger side first, as mine also has. Hasn't appeared on the d/s yet though.
When the windows are rolled down, they are both rolled down, and when up, both up. I frequently have them about 1/3 down too (picture the corner formed by the door and A-piller, I place the top front edge of the window so that it appears to spring from that small corner. I do it because it's a point I can see to make sure they are symmetrically down when I want them open but not all the way)
The first year or 2 that I had it, I don't think I put the windows down at all. Trying to keep that new car smell, you see. lol As I barely drove it, it seemed plausible. But once I broke down and decided to take the tops off (which I was also avoiding so as to not get spoiled as I planned to make it into a hard top, but gave up on that for lack of money), I would do it whenever I could. Again, I tried not to let them get all the way down because I saw the panel bow out.
So basically, I have a low mileage car, with very little use, that was covered for about 2 years and never had the windows open or the tops off for about that same period of time, that, again for about that period of time, was babied and has since had SLP SFCs put on (bolted and welded), and it's already cracked.
Why do (comparitively) high mileage cars and even daily drivers not have this?
Why does it appear on one side before the other - and not always on the same side for each person?
It just doesn't seem like it could be the window motor/track. Not when my case is fully considered.
What I am thinking, and why I asked which side it appeared first on for people, is - is there some sort of stress placed on it when the door is closed, or perhaps closed hard... ? My passenger side has been slammed a lot (to my *severe* aggrivation), whereas my driver's side has only been closed hard a few times accidentally.
It hasnt happened to mine yet, thank god! But i do notice that when I roll up my windows all the way as soon it hits the top portion, the whole door panel moves inward!! Just a little but enought to be noticed.
I noticed mine cracked a few months ago when I had my windows tinted. The tinting shop denied they caused it, but I insisted they did. They finally had thier insurance pay for a new panel. I hope it doesn't happen again, those panels are expensive!
![](http://i32.photobucket.com/albums/d3/jrcws6/doorpanel.jpg)
#32
![](http://i32.photobucket.com/albums/d3/jrcws6/11-12-2005-28.jpg)
Any idea what the cost of the panel was?
#33
There was a thread on this awhile back. My older TA already had it on both sides when I bought it. From what I can remember from the thread, there is a staple behind the panel at the very spot where the cracks occurred. I meant to remove it from my new TA before it cracked, but I forgot about it 'til now. Looks like a Saturday project, plus I will not be lowering my window completely anymore.
#34
Originally Posted by HPP
Damn, that is a wicked split. Wonder what made that one curve backwards while the others have been straight.
#37
This is a very common problem with any 98-02 Firebird. My girlfriends 99 Firebird had both panels crack in the same exact spots on both door panels. Mine are also starting to do this. I have mentioned it before but had no takers, but I was considering a possible class action suit against Pontiac for this problem if they don't want to cooperate. This is an obvious defect in the craftsmanship of either the door panels or the door itself. Either way it is to common for it not to be worthy of a class action suit. These cracks occur in the same exact spots on every car, and on both door panels. I can run a rope from the crack on my drivers side door panel, to the crack on the passengers side and it is a perfect straight line. Again these cracks are all in the same exact spot. So does anyone want to pursue something against Pontiac to get this problem resolved? Perhaps an online website with a registry of sorts describing the problem with pictures of the problem.
#39
I was looking closer yesterday. Both tops of the panel under that black moulding sort of dip in that spot. I mean it's not straight. It's a definate design flaw.............I wonder if we can go after GM as a class action suit?
I beat the General before with my 00 T/A after they told me detonation was normal that ALL LS1's detonate.
**** them, needless to say, 6 weeks later I had my 01 on order. Sucks when a Girl knows more about that car then they do.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#40
I have the same problem on both doors. I use a premium plastic/vinyl care product, my car is garage kept and rarely driven in the winter.
It's a 2000 trans am convertable, the cracks appeared almost instantaineously at about 62K miles. The passenger side is completely cracked through down to the vinyl, the driver side is cracked through but currently only half way to the vinyl.
The suggestion about the window is a good one but what good is a window if you can't roll it all the way down.
I'm thinking that there must be a (sorry for stating the obvious)design problem.
Any ideas on where to get replacements?
