Sponsored by: CARiD
Ignition problems...
Old May 17, 2007 | 06:51 PM
00A4SS's Avatar
Default Ignition problems...
I just replaced the Bosch platinum plugs with NGK TR5 Iridiums, and a set of 8.5mm superconductor wires, and now I believe that the passenger side bank is not firing at all. The SES light just blinks when I start it, and the code comes up as multiple cylinder misfire. It smells as if running rich, seeing as how I believe to only have the 4 cylinders firing. It sucks, as it is beautiful weather, and I am stuck driving my Z/71 Tahoe... Any tech help?
*THERE IS NO REASON FOR HUGE TEXT AND FONT
Old May 17, 2007 | 08:44 PM
ShevrolayZ28's Avatar
Welcome to LS1 tech and thank you for using the extra large font lol.
9 out of 10 times it is simply a matter of not pressing the wires onto the plugs completely. You should hear two clicks when installing them. Go back out there and press those suckers on and I bet you'll be good to go.
Old May 18, 2007 | 02:07 PM
00A4SS's Avatar
Heard both clicks... I have had this car since July 04... This is the second time I have changed the plugs, and had no problems last time. I have taken them off and put them back on multiple times, to the same problem... I don't think I shorted out any coils, but could it be the input before the coils that could have gone bad? This is my first Gen III, but my third experience with it, and have had no problems of this type with any of the prior...
Old May 18, 2007 | 03:09 PM
98Camarod's Avatar
Maybe your plugs are cracked.
Old May 18, 2007 | 06:47 PM
Check the fuse boxes for a blown fuse. Also make sure the coil packs are plugged in securely.
Old May 24, 2007 | 05:38 PM
00A4SS's Avatar
Ok, I paralleled this post on LS1 forum, and got a few other possibilities, and have tried them all, yet to no avail... I'm getting desperate here, and would rather hang myself than drop it off for some shop to figure out... any other options?
