Sponsored by: CARiD
gauge ???
Old May 18, 2007 | 10:23 AM
1BADTALS1's Avatar
Default gauge ???
i was just wondering if thier was a way to test my trans temp gauge.. i hooked it up by putting a T in the line and then the sending unit in the T.. ok from day one it never worked so i figured i had it in the return line not the incoming line.. so i switched it and rewired it. bam its working. butonly worked for a day now its not working at all.. all the wireing is fine no cuts no nothing. my question was is thier a was to test the sending unit?? or the guage itself. its getting power the lights work and the neddle moves a tiney bit when you first start it up. but thats it.
thanks Mike
Old May 18, 2007 | 07:13 PM
curtisad's Avatar
did you drive around long enough to heat up the tranny fluid?
Old May 19, 2007 | 08:50 AM
1BADTALS1's Avatar
yes i drive around plenty.. put on about 100 miles in one trip and still nothing..and its not like its freezing outside.
