Sponsored by: CARiD
plastic starer cover
Old May 20, 2007 | 04:47 PM
jorgez28's Avatar
Default plastic starer cover
well for some reason the cover that goes to the block to cover the hole where the starter is was making a bad knocking niose so I cut half of it off. Is this OK or should I go and get a replacement???
Old May 20, 2007 | 09:20 PM
firechicken99's Avatar
i would go buy a new one asap as not having that cover leaves your flywheel right out in the open... not a good idea if you ever drive over any rocks or ****
Old May 21, 2007 | 04:34 PM
jorgez28's Avatar
well I cut the top part off the part that (Framed) the starter but left the bottom to cover the hole below the starter.
