Sponsored by: CARiD
Headlight problem. Low beam.
Old May 25, 2007 | 06:06 PM
2001 White Ws6's Avatar
Default Headlight problem. Low beam.
Figured I would post this hear and maybe get some help. My driver side headlight motor went out so I switched it out with a new one. After I did that the low beam light does not work. Switched back to the old motor and again doesn't work. It gets power, has a good ground, and bulb is good.
My high beams both work but only the driver side low beam does not work. My fog lights also do not work.
WTF is up with this junk?
Old May 25, 2007 | 07:14 PM
chavez885's Avatar
so neither motor works and the bulb IS good...not sure,anyone else?
Old May 26, 2007 | 12:15 PM
I switched out the motors because the gear inside was stripped. After I did this my low beam light does not work. I thought it might have been the connector on the new motor so I tried the old one again and it doesn't work with that one either.
So I buy a new low beam light and that doesn't work. It's getting power, it has a good ground but it doesn't work.
Old May 28, 2007 | 02:48 PM
ALPHA Q's Avatar
I have a similar problem
hi beams work but not the low beams
is there a fuse for them?
Old May 28, 2007 | 08:30 PM
99nbmws6's Avatar
mine did the same thing when i changed mine out all i did was kept switching from low to high beams and it finally came on. now will it work for you i dont know but its worth a shot.
Old May 28, 2007 | 11:07 PM
Doubt that will work. I've switched them on and off enough times where if it were to work it would have already.
