Sponsored by: CARiD
No Vaccume at all!!
Old May 26, 2007 | 05:05 PM
02' hawk's Avatar
Default No Vaccume at all!!
I was at the track last night and noticed that after the run i had no vaccume on the vaccume gauge at idle. So i parked the car and hooked a vaccume gauge up and NO VACCUME to hold the by-pass valve open by the s/c head unit. I had followed the small vaccume hose up all the way to the passenger side by the a.c. box and no vaccume there either and i don't see where it goes from there. I don't know where it draws the vaccume from. My question is where does this vaccume come from?
Old May 29, 2007 | 11:13 PM
WILWAXU's Avatar
The tube you talking about connect to the intake near the MAP sensor. It provides vacuum for the A/C system. If it's off, your A/C will only blow through the defrost vents. It would cause a vacuum leak too..
Old May 30, 2007 | 04:54 AM
waldershrek's Avatar
I hate vaccume leaks! Be glad you found yours.
