Sponsored by: CARiD
a/c not working right
Old May 30, 2007 | 05:00 PM
pHEnomIC's Avatar
Default a/c not working right
When i installed my cam, we accidentally broke a pipe. I replaced the pipe with a fixed one, pulled a vacuum on the system for about an hour then filled it. It seemed to work fine in the winter. Now It is summer and it just isn't working properly. I turn it on and im pretty sure it kick on. It takes a while to cool down and it just doesnt get to the icy cold feeling it used to be at. I am positive there are no leaks. How do i know if it just needs more refrigerant or if there is another problem?
Old May 30, 2007 | 05:42 PM
2001NBMZ28's Avatar
Only way to check the charge is to put a set of guages on it.
Old May 30, 2007 | 11:05 PM
intense3123's Avatar
if the system is open for any length of time the desiccant in the accumulator will be saturated with moisture. moisture in the system will drastically reduce cooling. I'd change the accumulator, vacuum for a while, then recharge the system. That's only if you're positive there's no leaks.
