Strange Fuel Pressure Issue...
So I decide it has to be a fueling issue (too lazy to do a compression check at this point). I check fuel pressure w/o engine running. It seems good at 54 lbs (very minimum for these cars). I start the engine, and the needle on the pressure guage starts vibrating really fast b/w 60 and 70 lbs constantly. Pressure is supposed to drop w/ engine running. What could this be?
If you had no wheel spin and only cut a 2.15 60' then some is wrong.
