Sponsored by: CARiD
Normal Oil Pressure?
Old Jun 16, 2007 | 08:07 AM
KENS_SS_4's Avatar
Pressure = driven flow against the restrictions ( orifices, bearings etc.) as the restictions decrease (bearings wear) or flow lessens the pressure drops at any given rpm.
People here always jump to the pump. In my experience wear is the number one cause of low pressure (besides user fudge up).
Just something else to worry about.
Old Jun 16, 2007 | 03:52 PM
98 Z28's Avatar
I'm not worried about breaking anything using a larger filter, but does it hang down low to where it might get hit by something? I was just worried if I put a larger filter on there if it's just going to make it seem like the problem went away and then out of know where something just goes bad completely. Either way im going to change the oil and see what that shows.
Old Jun 18, 2007 | 12:08 AM
98 Z28's Avatar
Well I changed the oil, no metal or anything in it just oil. It was very dark though.
Old Jun 18, 2007 | 12:43 AM
98 Z28's Avatar
Originally Posted by Ryanmgaspard
There's alot of post on here that people said the longer filter fixed the pressure problem. It might not be anything wrong at all. Maybe you just need a longer filter. You should try it. What could a longer filter break?
I might give it a shot, the only thing that scares me is if that thing some how got hit while driving over a speed bump or something. I'm just beginning to wonder if i'm worried about something that is not a problem. When the engine is fully warm like 180-210* the pressure should still go up to 60 right? Or maybe like ken said things are just starting to show some wear.
Old Jun 18, 2007 | 12:58 AM
RickyMartinZ28's Avatar
Fram HP4 fits LT1... Longer filter
Old Jun 20, 2007 | 12:58 AM
98 Z28's Avatar
I might just try the larger filter. Where should the oil pressure be at 6000 rpms? I'm just wondering if i should park it until i have time to check everything out. I dont think there is a problem in the engine because the oil was clean and there was no metal on the plug.
