Sponsored by: CARiD
Quick HELP AC
Old Jun 11, 2007 | 07:27 PM
partyhardoo69's Avatar
Default Quick HELP AC
so i got no AC... got voltage to the compressor and compressor is not engageing..pretty much means its locked up correct?
cant put 134 in because compressor isnt moving to suck it in..
some one have a quick idea before i go get a new compressor?
Old Jun 11, 2007 | 08:40 PM
sroach20's Avatar
check the low pressure switch.
Old Jun 12, 2007 | 12:56 PM
we tried it. i ended up buying a new a/c compressor last night. I'll try and get it in today.
Old Jun 13, 2007 | 09:21 AM
okay well after bench testing my old compressor i found out it was fine. we found out the problem is the plug going into the compressor. I don't know if its just a bad plug or what.
Where does that plug go to. I saw it plugs into the compressor and then gets hidden behind the wiring harness. I'm going to go to the dealership today to get the plug/wires but i don't know where it goes on the other end.
Old Jun 13, 2007 | 10:52 AM
Greggy's Avatar
On an LS1, the compressor is controlled by the computer (PCM). It will run continuosly when switched on ulness you are at close to full throtle or in the R134A line pressure sensor is reading low.
Old Jun 13, 2007 | 11:13 AM
my problem is the compressor isn't getting the signal to pop out and start spinning. when i jumped it right from the battery it worked perfect and blew cold air. I tried jumping the switch and no go. the fans turned on but the compressor didn't spin. so is it possible the connector is bad? and if it is i will pick up a new connector and where does the other side of that connector go to? the pcm?
