Sponsored by: CARiD
Alternator
Old Jun 19, 2007 | 08:58 PM
Josh Nickelsen's Avatar
Default Alternator
I am going to have the alternator on my car rebuilt this week and I need to get it off. I haven't done one on an LS1 before so I just want to know what is the easiest way and will I need anything besides simple wrenches. I tried a search and it isn't working for me. I just don't want to get started and not have something I may need. Anything I should be careful of?
Thanks for the help.
Old Jun 20, 2007 | 02:33 PM
Dal1as's Avatar
Gear wrenches help but aren't really needed. Just make sure you disconnect your battery before you do it. I blew a hole in my low pressure power steering line because I thought I had disconnected the ground fully. Patience in getting it out but you shouldn't have a problem getting it out from underneath.
Old Jun 20, 2007 | 11:22 PM
Flawless02SS's Avatar
The most helpful thing will be a lift! Just take your time and you should have no problem. I just changed mine 2 weeks ago.
Old Jun 21, 2007 | 02:37 AM
Wish I had a lift!! I am going to have to do it with jackstands. I hope I can get my car up on them. It is lowered plus I have the factory GFX on it. I put a rhino ramp infront of the tire and the GFX hit right away. Hopefully 2x4's will work!
