Sponsored by: CARiD
idling issue stock 01
Old Jun 29, 2007 | 06:48 PM
fortmyerspolice's Avatar
Default idling issue stock 01
Today all of a sudden my 01 t/a m6 is idling funny. It like to get down low at 450 500 rpm then go back to normal at around 800 or so. Wierd thing is is that every time I give it some gas it starts to go back down to 450 500 rpms. Was running perfectly fine, not throwing any codes either.
Old Jun 30, 2007 | 09:08 AM
nobody know whats wrong?
Old Jun 30, 2007 | 10:40 AM
5301113's Avatar
Sounds like a vacuum leak. Check your brake booster hose
Old Jun 30, 2007 | 10:42 AM
brake booster is tight
Old Jun 30, 2007 | 11:12 AM
5301113's Avatar
check all your throttle body hoses.
You could have a craked hoses. remove them one by one.
Old Jun 30, 2007 | 11:20 AM
sixvi6-camaro's Avatar
My PCV hose had a carck in it and the car did the same. Also check the MAF screen. I've seen it where a leaf gets into the airbox and sticks on the MAF screen causing a weird idle problem.
