Sponsored by: CARiD
AC Compressor Clutch
Old Jul 6, 2007 | 10:52 AM
bczee's Avatar
Default AC Compressor Clutch
I don't have manual.. 99' Camaro with LS1.. what tool is needed and or procedure to remove and replace the Clutch unit on the AC Compressor ?
link or simple reply will be good, thanks in advance.
Old Jul 8, 2007 | 05:50 PM
SSHADOW's Avatar
I would like to know also. Thanks
Old Jul 8, 2007 | 09:26 PM
iggys11secz's Avatar
you will need a hub and drive plate remover/installer. you can probably rent one or borrow one from a local parts store. they should come with instructions on how to use the tool. basically uses the same theory of a power steering pump remover/installer.
