Sponsored by: CARiD
Electrical issues.
Old Jul 7, 2007 | 03:30 PM
DKITCHEN's Avatar
Default Electrical issues.
So my car has been running perfect ever since I put the new power steering pump in. I finally bite the bullet and replace my bad A/C line and pay for the evac and recharge. A/C blows nice and cold now, but... by the time I got home from the shop my check gauges light is on and the volts are reading low. I tried checking the connections and it just kept not charging, so I figured the alt. finally bit it. Put in a brand new alternator, charges initally then stopped again. Figure it must be a bad battery so I buy a brand new battery and still no go. It acts like the alt. is halfway working if that's possible. The car will run for a long time, but it won't show out of the yellow on the voltmeter??? Is there something they could have done during the recharge that jacked up my electrical system?
Old Jul 7, 2007 | 09:44 PM
gnomee's Avatar
Check all your connections, maybe your ground was loosened or something during the install of the ac?
Recharge should not have taken anything but hooking to your line and filling it with gas. There is nothing to disconnect or anything.
Sorry I could not be more help. TTT..
Old Jul 8, 2007 | 08:48 PM
iggys11secz's Avatar
grab yourself a dvom (digital voltmeter) and see what the alt is actually putting out. if it's anything under 13 or 13.5 volts, you may have just gotten a bad alternator. i have seen it a few times at our shop especially with remanufactured ones. otherwise just make sure all your grounds are good.
Old Jul 9, 2007 | 11:05 PM
DKITCHEN's Avatar
It was a bad connection on the single wire that goes to the regulator. I had to buy a new harness because the connector itself was in bad shape.
