Sponsored by: CARiD
Low voltage
Old Jul 19, 2007 | 10:45 PM
kraemer94's Avatar
Default Low voltage
When I first start the car after a few hours of sitting I get normal voltage readings from inside the car. But as the car warms up and I use my headlights/turn signals, my voltage goes erradic especially at idle, a little in the red. I figured it could be the alternator, voltage regulator, belt, or battery problem. Took the car to Autozone and had them test the battery. I bought a reman Alternator thinking that would fix my problem but it did not. I also change the belt no luck with that either. can anyone help??
Old Jul 21, 2007 | 05:39 PM
kraemer94's Avatar
bump up
Old Jul 21, 2007 | 08:12 PM
2001NBMZ28's Avatar
When a buddy of mine had a bad alternator on his 2K he went through two remanufactured parts store units and still had the same problem. It took a new OEM GM unit to fix it. Could be the alt isn't working when it gets hot.
Old Jul 21, 2007 | 08:51 PM
94'BLKBRD's Avatar
check your battery connections,my voltage was going to the red also but on the high side!My headlights were going out and coming on,so I disconnected my battery and connected it with a new bolt and everything is normal now.
