Found big problem after door panel removal!
The 3 bolts that hold a bracket for the motor and window regulator came loose and ripped through about 1 inch of fiberglass.
Here is a picture I got from shbox.com's tutorial. I circled the three bolts that came loose.
Since the bolts came loose, it allowed that bracket to move. So everytime I rolled the window up it torqued down that bracket causing the bolts to tear through the fiberglass.
I have no idea what to do. Anybody with any ideas?
If this is the case could you use large washers facing outside to hold against whats left of the fiberglass?
I bought new bolts, washers red locktite and I have some jb weld in the garage. Lets hope it holds, thanks guys.
Here is how I handled it:
https://ls1tech.com/forums/appearance-detailing/442192-window-motors.html
(Check out my post #19 on the first page and further conversation on the second page)
