Sponsored by: CARiD
Help P1637
Old Aug 3, 2007 | 07:08 PM
JonB's Avatar
Default Help P1637
Generator L-terminal circuit
I've done some searching and it seems to be that I need to replace the connector and the red wire that is connected to the alt. So where does this red wire connect to? I thought I saw that it connects to the pcm but where on the pcm? Also is this the end all cure all fix for this code or could it be my alt going bad? The voltage runs low and the check guage light is on at idle but once I get going it goes off but the voltage is still low(just barley in the red).
Thanks
Jon
Old Aug 3, 2007 | 11:58 PM
GOaT Cheese's Avatar
It's probably a smoked alternator.
Old Aug 4, 2007 | 02:43 AM
Dmoney's Avatar
That is the plug right on top of your alternator. Get that replaced. I went through 3 alternators before I realized that was the culprit to my alternator problems. It may look fine, but that one little wire doesn't have much slack. I got mine at the dealer. They will give you one that has three wires, just cut the ones you don't need.............
Old Aug 4, 2007 | 08:07 AM
JonB's Avatar
So where does this wire plug into other than the alt. It does plug into the pcm correct? But where excactly?
Old Aug 4, 2007 | 11:40 AM
staringback05's Avatar
plugs into the the top of the alternator and just the wires and follow it back to the pcm from there
Old Aug 4, 2007 | 06:03 PM
JonB's Avatar
It was the alt. Changed it and all is good again.
