Sponsored by: CARiD
check gauges, HELP!
Old Aug 6, 2007 | 08:16 PM
thosewhohatedmecreat's Avatar
Default check gauges, HELP!
Ok so I replaced my alternator because the CHECK GAUGES light came on, I fired the car up and YAY! the voltage is normal and the check gauges light is gone, i drive it around a lil, take it home, park it. I go to drive it again, i turn on the ignition and the check gauges light is back, I assume it will go away as I start the engine, so I start the engine and WTF? My voltage is low again and the check gauges light still there. Someone please help
Old Aug 6, 2007 | 08:22 PM
Intense's Avatar
Battery? Check Gauges is your gas is low... The battery is just bad and cant hold a charge. Get a good battery and you should be set.
Old Aug 6, 2007 | 09:26 PM
PureWS6's Avatar
The check gages light will come if you are low on gas....if not battery.... check grounds?
Old Aug 6, 2007 | 09:31 PM
chaman's Avatar
Check also the little damn wire that goes on top of the alternator. It is easily missed.
Old Aug 7, 2007 | 12:40 PM
That wire is in, but I am thinking maybe there is a bad connection, Im gonna pull it again today. I have tons of gas, think it could really be a bad battery?
Old Aug 7, 2007 | 04:59 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Moving to General Maintenance & Repairs...
