Sponsored by: CARiD
Help i cant see!!!!!
Old Aug 8, 2007 | 09:31 PM
98HAVACTA's Avatar
Default Help i cant see!!!!!
Hey does anyone know how to get better lighting with these sealed beam headlights? Is there a conversion kit to use halogen bulbs?
Old Aug 8, 2007 | 10:14 PM
sroach20's Avatar
i helped a buddy rip the bulb out of a sealed beam and used some epoxy to stick some silverstars in the housing. we then changed the headlight plugs and they worked until he played chicken with a parked truck, the truck won!
Old Aug 8, 2007 | 11:30 PM
VIP1's Avatar
Copy & Paste Moderator
Lighting FAQ:
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
(Its in the "Hall of Fame" sticky in the "Appearance & Detailing" section.)
At one point I made my own conversion housings to fit a H7 bulb into a 4703 housing, but it eventually filled with water and a loose connection melted the stock connector.
Here is a thread where I talk about it:
https://ls1tech.com/forums/showthrea...hlight=housing
Old Aug 8, 2007 | 11:36 PM
snake charmer's Avatar
you can buysome cheap replacement housings that fit aftermarket bulbs from the autostore . this way options of better light bulbs .
Old Aug 9, 2007 | 08:21 PM
Formula413's Avatar
You can't get silverstars to fit your car? I got some for mine, of course the LT1 cars were different, just one headlight for low/high beam. I thought they made those for everything. They work a little better than the stock headlights, they don't have that orange-ish tint to them, nice and white.
