Sponsored by: CARiD
Screeching sound when pulling off in first
Old Aug 10, 2007 | 01:44 AM
dgadson's Avatar
Default Screeching sound when pulling off in first
For about a month I have been receiving a screeching sound when pulling off in first gear in my 02 TA. Initially, I thought it was the rear calipers not releasing but several individuals stated the brakes look fine. Now I'm starting to wonder if this sound is coming from the rear end. Its only intermittent coming out of first and primarily with normal driving. Does anyone have any ideas?
Old Aug 10, 2007 | 09:06 AM
rd_ls1_z's Avatar
Did they look at the parking brake too? And are you sure it's in the rear and not a belt?
Old Aug 10, 2007 | 11:44 AM
dgadson's Avatar
I forgot all about the parking brake, it is very comparable to the parking brake being left up. When I pull off the rear tires, how do I examine the parking brake?
Old Aug 10, 2007 | 11:56 AM
rd_ls1_z's Avatar
You have to take the caliper and rotor off. Then the parking brake will be visable, looks like the old drum brakes. I would probably look to see if the shoes contact the inner drum and seize a bit, I would think rust marks or other wear marks (some help on that one), worn shoes, or maybe the shoes just need a bit of adjustment. The adjuster is similar to the old drum brakes. I'm not sure how to check the release of the shoes though, you might be able to actuate the parking brake to see how much, if at all, the shoes move. That's my idea, hope it helps a bit.
Old Aug 10, 2007 | 01:37 PM
TheLS1Kid's Avatar
dgadson, is your car an M6?
Old Aug 10, 2007 | 03:22 PM
dgadson's Avatar
Yes it's a M6 have you had the same problems?
Old Aug 10, 2007 | 03:38 PM
TheLS1Kid's Avatar
Don't hold me to it but I'm 99% sure its your throwout bearing.
Its a screaching rattle sound right?
Old Aug 10, 2007 | 07:32 PM
dgadson's Avatar
There's no rattling sound to it. I just replaced the bearing when I changed the clutch about 6 months ago. Could they go bad that fast?
 Michael S. Palmer
Old Aug 10, 2007 | 09:35 PM
TheLS1Kid's Avatar
I'm sure its possible for them to go out that fast. I'm not saying yours is toast though.
Its hard to say now that I know your TO bearing is fairly new.
Does it sound like squeaky brakes when coming to a stop?
Old Aug 10, 2007 | 10:03 PM
dgadson's Avatar
coming to a stop there is no noise at all. I just finished lifting the car up and will inspect the parking brake. Hopefully, that will be the problem. I acutally changed the brakes about 3 weeks before the noise started occuring. I will keep you posted and thanks for everyones help who chimed in.
Old Aug 10, 2007 | 10:15 PM
TheLS1Kid's Avatar
Anytime man. Let me know because is have a screech/rattle when I start out in first gear and it think its my TO bearing. Its nothing serious, the sound just annoys the **** outta me.
Old Aug 11, 2007 | 03:33 AM
dgadson's Avatar
Well, I believe I found the problem. My driver side rear caliper have way to much play. So much that the rotor moves fairly freely and I confirmed that the sound was coming from there. I did another search on calipers and found this post. This could very well be the problem.
https://ls1tech.com/forums/showthrea...hlight=caliper
Old Aug 11, 2007 | 09:24 AM
rd_ls1_z's Avatar
If the wheel is off, the rotor will move freely. Now, the caliper could be loose, and needing a shim. Did you notice one when you re-did the brakes?
Old Aug 12, 2007 | 10:05 AM
Arc00TA's Avatar
My car makes the same noise once in a while when its been sitting for a day or so, but its an A4 and the brakes are brand new. I'm going to check the parking brake.
