Sponsored by: CARiD
Problem With lumbar In Drivers Seat.
Old Aug 13, 2007 | 03:16 AM
Cheetoh's Avatar
Default Problem With lumbar In Drivers Seat.
I have a 2000 Firehawk. I can feel the Lumbar and Side Bolster Inflae. but they will not Deflate. Anyone have any ideas Why?
Old Aug 13, 2007 | 04:55 AM
CRAGER's Avatar
Administrator
Lightbulb
How can you feel them inflate when you claim they never deflate? They would be full of air already!
Only thing I can think of is the switch. If there is anyway, try to remove the passenger's side switch and see if you can use it on the driver's side to test it out.
If that does not work, maybe try a buddies switch on your car.
Peace,
Craig.
Old Aug 15, 2007 | 11:01 PM
sdm1234's Avatar
I have the same problem, only my side bolsters with deflate, and not inflate... I'm curious as to what the problem is, as well.
Old Aug 16, 2007 | 01:54 AM
Cheetoh's Avatar
Well, I found the Problem on mine, I pulled the seat out and looked at the Switch where the Wire harness Plugs into it and I Found that 1 of the Pins was bent and not going into the Connector on Both Switches, I bent the Pin Back Up and Plugged it back in and Now they both work like they should!!
