Throwing serpentine belt
Should I get the Katech belt tensioner? For those that have had this problem, what fixed it and what didn't fix it?
Thanks
As far as misalignment goes - first culprit I would check is the PS pulley - it only has press fit on pump shaft with no other mechanical holding method.
I have a TurnOne PS pulley and Katech solid tensioner. Just recently I had a problem with the PS pulley slightly walking off the pump shaft. I threw the belt during a 'highway sprint' with a hemi Charger
(luckily it actually just sat contained in the front of the engine and did not get caught up/destroyed).I re-installed the belt and as soon as I turned the key - belt flew off again!?
Took me a while to see that the PS pulley had walked off the shaft by about 1/4" - throwing off the alignment. I pressed the pulley back on to stop and installed a 3/8-16UNC bolt with washer and Loctite into the end of the pump shaft to retain pulley should this ever happen again.
Other than this problem regarding PS pulley, the solid tensioner has never failed me.
BTW, the Charger LOST
-Jay-
