Sponsored by: CARiD
cracking sound from drivers side steering components
Old Aug 24, 2007 | 04:18 PM
Cherub's Avatar
Default cracking sound from drivers side steering components
There is a cracking sound coming from somewhere on the drivers side. It only makes the sound when turning. My dad and I tried to pin point the sound but couldn't. It only makes the sound when there is wait on the drivers side so I am assuming it is a ball joint. I'd like to grease it but don't know how to do that on this car. Any comments would be appreciated. And I just ordered sub frame connectors!
Old Aug 25, 2007 | 06:47 AM
blade2222's Avatar
ball joint or wheel bearing, some cars have greese fitings under the ball joint some are sealed.
Old Aug 25, 2007 | 12:33 PM
dailydriver's Avatar
Check/grease the outer tie rod ends as well. If you've never replaced the ball joints/tie rod ends/etc. you may NOT have the zerk fittings which allow you to grease these components. I don't remember if they came from the factory or not with these (I replaced all of mine a while ago). Anyone??
Old Aug 26, 2007 | 01:37 AM
waldershrek's Avatar
Put it on a lift or jack stands and have somebody look at it while somebody else turns the wheel. Then you'll know
