Sponsored by: CARiD
high idle
Old Aug 27, 2007 | 11:44 AM
ls1transam346's Avatar
Default high idle
ive done a search but no clear answer for me. i just put an ls6 intake and longtube headers on. i will go drive the car and when i push the clutch in the rpms are at about 1500-1800 then slowely start to drop down to normal idle. after driving around awhile it will be fine as in i push in the clutch and it drops to normal idle right away. i shut the car off then after visiting a buddy i get in crank it up, start driving and it does it again. (same process). any ideas?
Old Aug 27, 2007 | 11:48 AM
TLewis4095's Avatar
Could be a vacum leak....have you had it tuned yet? You changed enough that it may need a tune, but I suspect a vacum leak.
Old Aug 27, 2007 | 04:59 PM
keliente's Avatar
Sounds like a vaccuum leak.
Old Aug 27, 2007 | 08:28 PM
i did not tune it yet. i will look for a leak but i did replace the pcv lines. also this past time i drove the car at first it was fine through town for about 10 minutes. then after driving on the interstate it had the high idle again
