98 z28 Idle Problems
My friend just picked up a 98 z28 and within the first thirty minutes of having it, it died on the highway and is running like complete crap now.
When we got it towed back to his house we started up the car and it was running and idling fine. Then the idle started acting up and dropped a couple hundred rpms and then it was finally sputtering around 200 rpms and then completely died. Now when we try to start it all it will do is sit around 200 rpms. Even if it does go up to 500 rpms and we give it gas, it bogs down and dies.
So I was just thinking of some basic things it could be:
Such as the TPS, MAF or maybe the IAC. I am going to try to clean those with him tomorrow but is there anything else i should look for?
The car also only has 47000 miles on it but sat for many years and recently got a tune up and all the fluids changed. It also just sat for the past 3 weeks.
Thanks,
Dan
Thanks for you help so far guys... Also do you know if autozone will do a rental a tool program with a scanner, since we wont be able to actually bring the car there?
Thanks,
Dan
This is actually my car that we are working on...Now the fuel pump does not prime at all and there is no pressure in the rails at all. The car wont even start.
We ran the car for codes today and got these 3.
We got this code twice
P0108 - MAP/BARO Circuit - High Input
P0506 - Idle Control System - Low RPM - Guessing this one since the car can't start up
So what do you guys think?
