Sponsored by: CARiD
Motor Mount Question
Old Sep 16, 2007 | 04:17 AM
SSMOKIN_Y2KSS's Avatar
Default Motor Mount Question
ok so i have a pretty serious build on my camaro and im having sum driveline issues im running 400 and a few hp and slightly more tq and coming from 2nd to 3rd gear (M6) when racing will shift into almost like an unknown gear i think its going into reverse cause ppl tell me my reverse lights go on but then u have to pull it back pretty hard to get it into neutral again and then today i was doing freeway pulls and i tried to go from 3rd to 4th and it ended up going into 2nd luckily i dont think i did any damage but either way u wanna b scared at 120 or so thats the way to do it im thinking this is maybe cause of bad motor mounts this is happening im not so sure i have bmr suspension components torque arm and subframe connectors with strut tower PA racing k member and i dont have a reason for this yet..but this bugs me cause i intend to have alot more power approx in the 800 range and this is a big problem for me ...i was thinking maybe its a worn out shifter i mean it is a pro 5.0 but it is a lil old..im not sure totally confused also about the solid motor mounts who thinks what about them verses poly..whats the best choice its not a daily so the vibration isnt really an issue cause i kno thats the first thing ppl say about them. whats the most logical way to go if it matters its gonna b turbo'd
Old Sep 16, 2007 | 10:34 AM
sixvi6-camaro's Avatar
uhhh.. what? worlds longest run on sentence.. seriously try some punctuation when you post. I don't understand 90% of your post but from what little I gather you have a pretty serious drag setup and want to know about motor mounts? I'd just get solids in your case. It will vibrate a bit more than polys but be the best for a drag car as it will keep the engine solidly in place and piping and exhaust will not shift and bang at all.
